capitanmelao
Dec 27, 2016Guide
Cannot Access orbilogin.com or net
Hello
I just did install an Orbi router and its satellite , all goes fine, there is internet and sofar all is working well. the problem now is to get access to the admin page, i saw that it was changed to 10.0.0.1 to not to have problems with my router, in my configuration there is a router 192.168.21.1 that is attached to the modem 192.168.1.1 in the basement, there is a cable in the first floor where i did install the router Orbi, so when I try to enter I think there is a conflict there. With the app in the iphone it does not recognize the orbi network and the router, when i try to enter using orbilogin.net or 10.0.0.1.I can not ccess neither, I always have the same page of not found with the url and it is thinking all the time with the IP, I did manage to enter only with the cable and disconeting the internet router that gives internet to the Orbi and I did changed the IP of Orbi to 192.168.24.77, but anyway when I out back the cable it is not working. Please help me! thanks in advance.
guys i did solve it, I did set the IP of the Orbi to 192.168.1.1, the same IP of the main router and now it is working perfectly, it recoginizes the orbilogin.com and entere also with 192.168.1.1 in the browser, thank you very much!
Guys thank you very much for the answers, I am trying right now in the house of the friends that I installed the router, I will try with each answer I will let you know as soon as I get something, thank you!
- DarrenMSr. NETGEAR Moderator
Hello capitanmelao
Have you been able to resolve this issue?
DarrenM
No :(
Does orbilogin.com work if the Orbi is in AP mode? Is the OP using their Orbi as their main router or AP mode?
