Blackdiamond
Oct 21, 2017Aspirant
Cannot access server Readyshare on iMac
I bought the Orbi router this month. It works fine except I can't connect it as a server to the Mac, and therfore cannot use it with an USB HDD. I'm using iMac OS Sierra, and follow the recommended ...
st_shaw
Oct 21, 2017Master
I do not believe Orbi supports sharing USB HDDs. I believe it only supports printer sharing via the USB at this time.
Blackdiamond
Oct 29, 2017Aspirant
If it accepts an HDD for time machine,(see kb.netgearsupport.com/21360)it must accept any HDD. but while trying to connect the server, I don't even get the pop up asking for a password for registered user and the connection fails.
I’m open to any good solution.
Thanks
- st_shawOct 29, 2017Master
Blackdiamond wrote:
If it accepts an HDD for time machine ...I don't believe it accepts an HDD--not for time machine nor anythign else.
Until Netgear adds this feature the only solution is to put your HDD on another device attached to the network.
