Blackdiamond
Oct 21, 2017Aspirant
Cannot access server Readyshare on iMac
I bought the Orbi router this month. It works fine except I can't connect it as a server to the Mac, and therfore cannot use it with an USB HDD. I'm using iMac OS Sierra, and follow the recommended ...
Blackdiamond
Oct 29, 2017Aspirant
If it accepts an HDD for time machine,(see kb.netgearsupport.com/21360)it must accept any HDD. but while trying to connect the server, I don't even get the pop up asking for a password for registered user and the connection fails.
I’m open to any good solution.
Thanks
st_shaw
Oct 29, 2017Master
Blackdiamond wrote:
If it accepts an HDD for time machine ...
I don't believe it accepts an HDD--not for time machine nor anythign else.
Until Netgear adds this feature the only solution is to put your HDD on another device attached to the network.
