HR21's avatar
HR21
Cannot connect my Carrier Infinity Thermostat
I have a Carrier Infinity Thermostat that used to connect to internet with no problems on my previous 2 routers (Previous Century Link and Netgear routers). Now, it cannot connect to my Orbi, despite that it shows on my connected devices list when I log into my orbi router.
Anybody else had this problem? Any solutions?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you checked if it needs to be connected to a certain band at all times some smart devices do not like mesh networks.
    DarrenM
    • DavidShawP's avatar
      DavidShawP
      Star
      I had that problem with my Ring devices.  It turns out they are on 2.4 GHz only and need a channel between 1-11.  I set the channel manually and it works well now.  You could try that.
      • HR21's avatar
        HR21
        Thanks for the tip. I tried to maulay select the 2.5G band to channels 1, 6 and 11.. tried all 3 but did not work.
