Lars157
Dec 06, 2017Aspirant
Cannot connect orbi satelite
Dear community,
I have lost connection with my orbi ac3000 satelitein the manual.
According to the manual, I must syncronize with the satelite, when the white light is still, but it keeps flashing white(for a few days now.).
I didnt observe when I lost the connection, but I have changed internet provider recently. maybe it has something to do with that.
Can anybody guide me to a solution.
Regards
Lars
Have you taken your network through the same steps you used in setting it up?
- Lars157Aspirant
Yes, I have already done that. My network is up and running, but I still cannot connect with the satellite. Do I have to change the ip-address for the satellite, and if so, how do I do it?
Regards Lars
- DarrenMSr. NETGEAR Moderator
I would try to factory reset the satellite then try to sync the unit again.
DarrenM
