orbi-user-1
Jun 30, 2022Follower
Cannot enable remote access
I am having this issue. Cannot enable remote access
What NG product are you referring too?
You gave us nothing to go off.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with. - ekhalilMaster
orbi-user-1 wrote:I am having this issue. Cannot enable remote access
Are you refering to remote access using the Orbi app or the web interface (orbilogin.com)?
There can be many different causes behind most problems. There is not much anyone can suggest without further details.
Apart from telling us nothing about the Netgear devices you own, you have not said anything about what you are doing and where things go wrong.
Did you find any of these?
Enabling your router's remote management | Answer | NETGEAR Support
How do I enable remote access on my router using the Nighthawk app? | Answer | NETGEAR Support
What functions can I manage using remote access in the genie mobile app? | Answer | NETGEAR Support
