Jorgeelizondom
Jul 15, 2024Follower
Cannot sink RBS50 satellite via Ethernet backhaul
Hi, I factory reset the satellite, then synced it wirelessly placing it next to the router. It synced perfectly and they are now both on the same firmware. I now take the router to the remote loca...
CrimpOn
Jul 15, 2024Guru - Experienced User
Agree with FURRYe38 that it is a good idea to test the satellite's Ethernet connection in the same room with the router (and obviously a different cable). Might not hurt to eyeball the RJ45 port on this replacement satellite to see if any of those tiny gold wires are bent.
