Jorgeelizondom
Jul 15, 2024Follower
Cannot sink RBS50 satellite via Ethernet backhaul
Hi, I factory reset the satellite, then synced it wirelessly placing it next to the router. It synced perfectly and they are now both on the same firmware. I now take the router to the remote loca...
Jul 17, 2024Guru - Experienced User
Any progress on this?
Jorgeelizondom wrote:
Hi,
I now take the router to the remote location connect the Ethernet cable and turn it on. (No switches between the router and satellite). It does not connect via Ethernet, it still connects wirelessly.
The Ethernet cable is good; it was working perfectly with another RBS50 that dyed.
Please help. What is the proper way to setup this connection via Ethernet backhaul?
