NamBot3000
May 06, 2017Aspirant
Can't access orbi settings via website or app.
So I rearranged my network the other night. I ended up putting the orbi in AP mode, and plugging it into my router (an AT&T provided PACE 5268AC). Now I can't access the orbi settings. If I try to us...
- May 06, 2017
You have a few options.
1) Login to your PACE 5268AC and locate the IP address assigned to the RBR50 by the router. Use that IP address in your browser to open the Orbi settings UI. I find it helpful to statically assign the IP addresses for the RBR50 and RBS50 in my router's configuration
2) Try routerlogin.net
3) See previous posts regarding this issue
DukeSilver
May 06, 2017Star
- NamBot3000May 16, 2017Aspirant
This works perfectly. Thanks!
