NamBot3000's avatar
NamBot3000
Can't access orbi settings via website or app.
So I rearranged my network the other night. I ended up putting the orbi in AP mode, and plugging it into my router (an AT&T provided PACE 5268AC). Now I can't access the orbi settings. If I try to us...
  • DukeSilver's avatar
    May 06, 2017
    You have a few options.
    1) Login to your PACE 5268AC  and locate the IP address assigned to the RBR50 by the router.  Use that IP address in your browser to open the Orbi settings UI.  I find it helpful to statically assign the IP addresses for the RBR50 and RBS50 in my router's configuration
    2) Try routerlogin.net
    3) See previous posts regarding this issue
