bayoyong's avatar
Mar 11, 2018
Can't Add Circle
Model is RBR20. Wasn't listed in list.
Trying to add Circle. Says it's built in. Says it's compatible. When I try to pair from the Circle app, it says I need to update the firmware. Click update. Eventually gives me an error message saying this firmware isn't compatible. Stuck in a loop. Can't pair. Brand new Orbi.
Thx.
  • Can you verify your model and firmware version? Best to login to the router through your browser and go to Advanced Tab to check router information.
    • bayoyong's avatar
      bayoyong
      Tutor
      Hardware Version   RBR20
      Firmware Version   V2.0.0.64
      GUI Language Version   V1.0.0.302
      Operation Mode   Router
      • Starbucky's avatar
        Starbucky
        Apprentice
        Circle is not included with firmware 2.0.x only the 2.1.x have Circle integration.
