Rikerrock
Jul 28, 2019Tutor
Can't change icons of attached devices
Have most updated firmware. I click on attached devices and then click on say a HP printer and I change the icon to printer. Says updating, but right back to standard icon. Any suggestions?
Dec 26, 2019Guru - Experienced User
Users should try v2.5.1.8:
https://community.netgear.com/t5/Orbi/Firmware-v2-5-1/m-p/1837488/highlight/true#M78401
Working for me. I didn't have to do a factory reset either. Users should try a factory reset on there systems with v2.5.1.8 loaded if they can't seem to get this working. Clear all browser caches as well. Using Opera for me is working with device naming and icon changing.
For some users which Orbi's out of warranty, give Voxels 3rd party FW or Orbi a try as well:
Keith_1952
Dec 26, 2019Tutor
You must be using an RBR50. This thread was originally around the RBR20, for which the latest firmware version is 2.3.5.36. Extrapolating from how quickly the support for the RBR20 was abandoned after the RBR50 came out, I'm sure you'll be joining our orphan ranks soon enough.
