Catalyst_oz's avatar
Catalyst_oz
Cant conect Robomaster S1 to Orbi setup but works fine with Nighthawk R8000
I am trying to connect my new DJI Robomaster S1 to my Orbi RBR50 but it never connects, so I pulled out my old Nighthawk R8000 and set it up on the test bench, the Robomaster connects fine to one of the 5G channels.
Started again with a reboot to my router and tried again but still no luck getting a connection.
The difference I see between the 2 routers is the orbi has bonded chanels and the nighthawk are all different, but that normally only matters on 2.4G and I am connecting on 5G
I have 2 Satelites and 84 other devices connected, from wifi power points to Cameras and everything in between. This is the first device I can not get to connect.
Router RBR50 Firmware V2.3.5.30
Satalite 1 RBS50 Firmware V2.3.5.30 Wired Backhaul
Satalite 2 RBW30 Firmware V2.3.5.6 Wifi Backhaul
The robot is setup by selecting you wifi the entering th password in a box, hit next and a 3D barcode is generated is then shown to the robot wo the says connecting, but in my case it never does.
