nightfat73
Jul 10, 2017Aspirant
Can't connect to Orbi's network
Just got Orbi AC2200 triband system. Tried to log in into both orbilogin.net and .com and get an error message of "You are not connected to your Orbi's WiFi network. To access orbilogin.com, your dev...
st_shaw
Jul 10, 2017Master
Are you able to connect to the Orbi's WIFI before trying to log in?
Did you try connecting with a cable to an Ethernet port on the router and then connecting to the Orbi's default IP?
- nightfat73Jul 10, 2017Aspirant
Yes for both.
- st_shawJul 10, 2017Master
OK.
Technically, not being able to connect to "orbilogin.com" means the Orbi is not the name server for your computer. This can happen if Orbi is in access point mode and another router is runnning, or if you computer is not geeting assigned an IP address via DHCP from the Orbi.
When you connect to Orbi, either WIFI or wired, are you able to reach the Internet OK?
Are you running Orbi in router mode (default) or access point mode?
Can you wire a Windows computer to one of the Ethernet ports on the Orbi router (not the yellow Internet port), run the "ipconfig /all" command, then post the Ethernet adapter section of the output? This will list your IP address, DNS server, gateway, etc.
- RfrymireJul 11, 2017Aspirant
I have an orbi pair in access mode and this morning the primary stopped responding to pings, though it still seems to be connected to all wifi devices. I am currently traveling and unable to do a power-off reset. Is there any other way to reset a device when it is in Access Point mode?
