melannie_mark's avatar
Mar 24, 2020
Cant connect
Just got the RBR40 Router with 2 satalites. I went throught the process of setting it up. Got both satalites to glow blue and I can see the router name on my wifi list of networks but when i click on it to use it nothing happens. no internet..... and on my laptop same thing i can see the name of the wifi but it says internet not connected. How do i trouble shoot?
  • Poor cat!! it is working!! that was it... needed to go back to factory settings.
    thanks
    • router is white and i have connected with the app on my iphone. Should i try to do it throught the website?
      • melannie_mark's avatar
        melannie_mark
        Tutor
        I think i just got it to work. i read one of your other posts about reseting it to factory settings and i think that worked... hang tight...
