Lanis's avatar
Lanis
Can't do firmware update
My Orbi is running firmware 2.0.1.4 (stable for 3 weeks) connected to an iMac, OS 10.13.4.  I read about firmware 2.1.3.4, so downloaded it for manual update.
I can log into my router, click on and work with all modules except when I click on Firmware Update; at that moment, the system goes into 'spinning wheel mode' forever.  I can click on other modules and move to those modules successfully, but I just can't get into Firmware Update.
Any suggestions about how to free up the router to let me get to firmware update would be greatly appreciated.
  • FURRYe38's avatar
    What browser are you using? Try Safari or FF browsers. Clear browser caches before and after trying to load the FW. Do no navigate to any other pages. Disable any PC security software temporarily.
    Be sure that your wire connected with the Mac to the router.
    Factory reset the router and set up from scratch if and when you get it loaded.
    If your not having any problems, you might keep whats already loaded. You don't have to update.
    • Lanis's avatar
      Lanis
      I normally use Firefox, so you convinced me to try Chrome.  It let me in to the Firmware Update module without hesitation.  Now I have a different issue.
      I have a different Orbi system (RBR50 + 1 Satellite) in a different house.  That system gave me a message to update my firmware to 2.1.3.4, which I did successfully.  This system, now that I am in the Firmware Update module, does not show my the 2.1.3.4 update.
      I wonder why one Orbi shows the update to me and the other system does not.
      The next question would be:  would I be in trouble if I do the manual update on this system, even though it is not giving me the recommendation to do this update?
      • FURRYe38's avatar
        You can do a manual update if you have the files already.
        I recommend being wired with the router and satellite with a PC.
