Bambang
Feb 02, 2018Follower
Can't See my 5Ghz Network on my RBK50
After setting up my RBK50, I noticed that using wifi analyzer and my killer wifi card, I can't see my 5 Ghz network. Is it there or is it off?
DarrenM
Feb 05, 2018Sr. NETGEAR Moderator
Orbi uses band steering and should switch your devices to the 5ghz network when it is the best connection for the device.
DarrenM
