TheoMerca
Jun 13, 2024Tutor
Can't set Orbi admin password or security questions after reset
Hello,
I have factory reset my Orbi Home Mesh System RBK22. After the first setting screens, I can't set a password or security questions.
The "Next" button is grayed out, with no choice of security question (1 and 2).
I'm on the http://orbilogin.com./cable_genie_redirect.htm screen
"Administrator account settings
The administrator password is used to connect to your router's web interface.
Secure your network by changing the administrator password."
The mobile application does not recognize the old admin password (connection expired).
What is the firmware version currently running on the RBR20 router?
When the router is Factory Reset, the login credentials are initially "admin" and "password".
Which Interest Service Provider is this router connected to?
Thank you for answering !
I have no way of knowing which firmware the RBK22 is running, I assume it should be up to date since it was working fine a few days ago.
The login in window doesn't appear when I connect to routerlogin.com or .net. I get straight to the Orbi set up.
It's connected to a french internet provider Bouygues, the WIFI network doesn't havge any issue.
Correct. That screen does not show any relevant information.
I have a WiFi5 Orbi (RBR50) and it does not include that web page. (Had to remove the extra period after 'com' to make a legitimate URL.) When I enter the IP address of my Orbi router into a web browser (http://192.168.1.1 , what appears on my screen is this page (http://192.168.1.1/index.htm )
Is the web browser device connected with Ethernet or WiFi?
