RobertWycoff
Dec 26, 2018Aspirant
can't sign in to Netgear orbi app
My Orbi app suddenly didn't show my two RBR50 satellites as being connected. I tried some things and now I can't log into the Orbi app.
I am able to go to 10.0.0.48 in my browser and see them as b...
RobertWycoff
FURRYe38 wrote:
How did you figure it out? So others might be helped by your experiences..
For some strange reason I now have to use the Remote Signon option on both the Orbi and Netgear apps.
My Comcast Gateway is in Bridge Mode and has been ever since I installed my Orbi.
Dec 26, 2018Guru - Experienced User
local sign in should work as well when your at home connected to the Orbi.
- RobertWycoffDec 26, 2018Aspirant
I agree. That's the way it has worked since I installed it 12/2017.
But I just can't get it to work now.
When I started the Orbi app the first time today, I didn't have to log in. But my two satellites were not connected in the app, even though they showed as conneced in 10.0.0.48 with my browser.
So, I thought I would try rebooting the system with the Orbi app and after that the only way I could log into the app was with the Remote option.
- FURRYe38Dec 26, 2018Guru - Experienced User
Might try removing the app and re-installing it to see if local side works...
- RobertWycoffDec 27, 2018Aspirant
I did that. The Genie app is also doing the same thing.
I suspect the reboot of the Orbi with the Orbi app caused the issue.
I reinstalled the Genie app and it does the same thing; I have to log in remotely.
