DrChocolate's avatar
DrChocolate
Follower
Apr 17, 2020
Can't update my firmware and it's stuck on V2.3.5.30
Hello!
I've got my netgear orbi for close to a year and since then I can't update my firmware at all. When I use the app it says that it's running the latest firmware. I tried the web method but no to avil. The online updates states that there's no new firmware available for both my satelite and router and the current version is V2.3.5.30, but i've check on the support website that the latest version is V2.5.1.8.
Hope someone can help me out!
Thanks in advance
  • Retired_Member's avatar
    Retired_Member
    DrChocolate wrote:
    Hello!
    Thanks in advance
    is your system working?
    is so, leave it alone.  NG will push critical updates to you no action on your part.
    stop looking for trouble
    OBTW....V2.5.1.8. has reported problems.....:smileymad:
  • FURRYe38's avatar
    You can manually download FW files from here:
    https://www.netgear.com/support/product/RBK50.aspx#download
    First do a backup configuraton to file on the RBR using a web browser.
    First unpack the .zip files. Apple RBS first then RBR lastly using a web browser. Using a wired PC is recommended.
    I recommend a factory reset and setup from scratch to ensure the system works well for you. You can re-apply the backup configuration from file as well.
    Make a new backup configuration to file afterwords.
    v2.5.1.8 does work for others as well:
    https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
    https://community.netgear.com/t5/Orbi/Orbi-Satellite-Drop-Connection-time-to-time/m-p/1890341/highlight/true#M88026
    https://community.netgear.com/t5/Orbi/Netgear-drops-the-ball-again-RBR50-on-FW2-5-1-8/td-p/1876302/jump-to/first-unread-message
    DrChocolate wrote:
    Hello!
    Thanks in advance
    DrChocolate wrote:
    Hello!
    Thanks in advance
      Retired_Member
      version V2.5.1.8 is NOT ready for prime time unless you want to be a beta tester
