Magnificent1
Jan 22, 2018Star
Can't Update Orbi Satellite Firmware
Hi. I bought a new Satellite from Best buy. Synced to my my router. On the connected Satelite tabs, it shows my two Satelites, but the new one I bought, for the "Backhaul Status" it says Config Sync....
- Jan 22, 2018
Hi, put everything back on RBS50-V2.1.1.16, then try to upgrade everything again to the latest version, but (VERY IMPORTANT) update your Satellites first! then finally update the main unit.
budy
Jan 22, 2018Luminary
Hi,
can you check the MD5 checksum of the downloaded firmware file. I just downloaded the RBS50 2.1.1.16 fw file and unzipped it. Mine shows this MD5 checksum:
687b6136e61b8cbb3be9d11135be959d
- Magnificent1Jan 22, 2018Star
Hi, is the same checksum. I have tried other firmware, and i get the same problem.
- ElyJan 22, 2018Luminary
I'm unable to flash any firware on the defective RBS50. I have tried flashing a couple of old versions, and none of them work, I keep getting message about incorrect firmware. The only one that takes the firmware is the other Satellite I have.
