Magnificent1's avatar
Jan 22, 2018
Can't Update Orbi Satellite Firmware
Hi. I bought a new Satellite from Best buy. Synced to my my router. On the connected Satelite tabs, it shows my two Satelites, but the new one I bought, for the "Backhaul Status" it says Config Sync....
  • Ely's avatar
    Ely
    Jan 22, 2018
    Hi, put everything back on RBS50-V2.1.1.16, then try to upgrade everything again to the latest version, but (VERY IMPORTANT) update your Satellites first! then finally update the main unit.
