GWild
Mar 04, 2019Guide
Can't Update Orbi Satellite Firmware
RBS20 Satelitte in CK40 kit.
When I installed the system in late January, I did upgrade firmware using the ONLINE update function.
A suggestion to upgrade the satellite firmware - but isn't happening because the satelitte isn't recognizing the default password nor the one the master was set to. I suspect the issue is I did change the system password at installation - but did not think to manually change the satellite password. And no, I did not retain the satellite sticker that had the preissued "system" password.
Is a manual update a known issue?
Or, am I in for a factory reset and figuring out how to retrain the satellite from scratch? Any hints on documentation to do that?
- GWildGuide
For those following this - so far no one, including the chat folks have even been able to understand I can't log into the RBS20 ...
If the satellite is not getting admin and PW from the CBR40 after a factory reset and setup from scratch, I would replace the CBK40 system or get it RMAd.
