Discoman
Jul 29, 2018Tutor
CBK40 Orbi with ATT Fiber
I currently am switching from Comcast cable to AT&T fiber with an existing CBK40 system. What is the best configuration for the AT&T box with the CBK40?
- Jul 30, 2018
Well, this has been my intuition all the way so thanks for confirming the facts. I will use the AT&T system with an expander that they provide to see if this is enough to cover my house.
I can't return the CBK40 so I'll try to find a way to provide value to someone.
Thanks for the advice on clearing the ISP as well. I'll get this off Comcast as soon as the AT&T is up.
Discoman
Jul 29, 2018Tutor
Thanks for the information. It looks like I might need a backhaul unit as well. I'll know more tomorrow following the AT&T installation. Since AT&T also sells Orbi units in their stores, the techs should be able to work with my CBK40 setup and make recommendations if required.
Jul 29, 2018Guru - Experienced User
Hopefully they can keep the Orbi cablemodem as the gateway. I can only run in gateway mode or bridged.
Good Luck.
- DiscomanJul 29, 2018Tutor
My concern is that the modem capability in the CBK40 might limit the flexibility as compared to the router only unit in the standard configuration. More tomorrow.
