Boggard11
Oct 25, 2020Aspirant
CBK752 Bufferbloat
Hi,
Just wanted to know if anyone else was having crippling Bufferbloat with their CBK752 modem / router. Causing me huge latency and very unstable streaming (twitch), have tried everything I could but seems pretty hopeless. Guessing it's a firmware issue? Can't seem to get the hidden qos page to do anything, and have tried a factory reset with no speed test to try to turn off all qos but to no avail
Cheers,
Richard
Cheers,
Richard
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).- Boggard11AspirantUsing firmware V3.2.16.9, connection is wired so I'm not sure changing wifi related settings should have an impact, right?
Didn't know your having problems on wired connections.
How is your device connected? Does this device have a ethernet port?
Be sure your using good quality LAN cable. CAT6 is recommended.
Test streaming and video with a wired PC or laptop to compare results...
