johmarien1
Mar 25, 2020Aspirant
cbr40 connect to wireless printer Epson workforce 845
the CBR doesn't connect to the epson. The epson connects to the CBR. Did you follow epsons manual, install guide, troubleshooting?
https://epson.com/Support/Printers/All-In-Ones/WorkForce-Series/Epson-WorkForce-845/s/SPT_C11CB92201
- johmarien1Aspirant
To respond to reply that the workforce845 connects to the router. Yes I entered all correct info into printer per epson web site 5 or six times w/ same result. Ran network check security key / password check failed they are correct ip adress unchecked / detailed ip setup check unchecked. The printer generates a pin code which it says to enter into the computer within two minutes. were would you enter that pincode. also ran Microsoft check and all is correct. printer is default . I'm not a techy. could it be ip address ?
