Bcadamsdc's avatar
Bcadamsdc
CBR40 Firmware 2.5.0.24
After latest firmware upgrade internet is dropping once an hour or more. Also the satellites (upgraded to the latest firmware) aren’t staying connected. One satellite that is cable wired is staying connected. Wondering if people have faced similar issues with latest firmware.
  • michaelkenward's avatar
    michaelkenward
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Orbi - NETGEAR Communities
    Those things are very different from the standard Netgear routers covered in this section.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    Not seen on Orbi AX.
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    • Bcadamsdc's avatar
      Bcadamsdc
      House is 3500 Sq feet single story and I'm running CBR40 router at one end of the house connected to Xfinity with an RBS40 on a wired connection to the router in the middle of the house and 2 RBS20 satellites connected wirelessly on 5ghz connections.  Network Map shows CBR40 wired to RBS40 with both RBS 20 satellites connected to RBS40 directly.  The RBS 20's are both about 30 feet away and one is in the attic.
      All FW is up to date and I did a full system reset on all units and brought them back one at a time. That seems to have addressed the satellite issues.  Yes, we have wifi neighbors but no new neighbors or observed changes.  I went ahead and matched the recommended configuaration changes and hope that will help - though it took a while for the satellites to reconnect.
      The main issue now is the router dropping the internet every 30 mins or so which would appear to be a router issue, not a wifi or wifi config issue.  My pc is hardwired to the RBS40 (which is hardwired to the CBR40) and the internet is still dropping out.  Router and hardwired connection has been super stable until this latest firmware update.
      What I have also noticed is that if I click on "Cable Connection" in the Basic Menu I get an error screen saying that the router didn't send a signal and then the internet drops.
