dstranathan
Jun 02, 2018Apprentice
CBR40 Modem/Router = No Spectrum Compatibility?
I pre-ordered the new much-anticipated Orbi CBK40 system (including the CBR modem/router combo) to replace my Spectrum OEM (Ubee) modem. I have been waiting months for this device and I was very exc...
- Jun 02, 2018
It's not on Cableone either. I was told to tell them the model is a CM700. Told my ISP this model #, which I checked it was already on there supported modem list. Gave them the MAC address and about 5 minutes later, BOOM. ONLINE.
Give the CM700 a try if this model is on there supported modem list. It works.
Jun 02, 2018Guru - Experienced User
I see thats new. Guess I'll start hanging out over there. Thank you Sir.
