dstranathan
Jun 02, 2018Apprentice
CBR40 Modem/Router = No Spectrum Compatibility?
I pre-ordered the new much-anticipated Orbi CBK40 system (including the CBR modem/router combo) to replace my Spectrum OEM (Ubee) modem. I have been waiting months for this device and I was very exc...
- Jun 02, 2018
It's not on Cableone either. I was told to tell them the model is a CM700. Told my ISP this model #, which I checked it was already on there supported modem list. Gave them the MAC address and about 5 minutes later, BOOM. ONLINE.
Give the CM700 a try if this model is on there supported modem list. It works.
st_shaw
Jun 02, 2018Master
dstranathan There is a new separate forum for the Orbi with built-in cable modem. You might get better response there.
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
dstranathan
Thank you.
