Poison192
Aug 24, 2026Aspirant
Certain android apps stopped working or are slower than before...
Hi there, Since a few days, I'm having trouble using a few apps on : 3 android phones (on wifi) -> Samsung Galaxy S7 Edge, Samsung Galaxy S10, Samsung Galaxy S21 2 tablets (on wifi) -> Sa...
- Aug 27, 2026
The problem is solved. I shut down IPv6 and all difficulties went away. Afterwards, I remembered I enabled IPv6, thinking it would additional benefits. Apparently it did not have any benefits.
Aug 24, 2026Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
FW version loaded on the Orbi system?
Brand and model# of ISP modem the RBR is connected too?
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
If the ISP and Orbi systems have been working well and only items of Android or Android apps has changed, would be something to contact Android or the Mfr of the apps about.
Poison192
Aug 27, 2026Aspirant
- FURRYe38Aug 27, 2026Guru - Experienced User
Sometimes IPv6 does have benefits. IPv6 needs to be native support at ISP first. If not, then ya, having IPv6 enabled on the system won't give much.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
