Geary's avatar
Geary
Challenges adding wired backhaul satellite in AP mode
I have a fairly basic network config that's giving me some trouble.
Issue:
RBR50 can't find the RBS50 to add it as a satellite. Attempts to add it fail both from the mobile app as well as the browser-based config.
Basic config:
RBR50 connected via a LAN port to a switch, into which both my incoming WAN link and an RBS50 are plugged. RBR50 configured in AP mode.
Other data
The RBR50 sees the RBS50 as a wired device and shows other devices connected to the LAN ports on the RBS50 as being wired to the RBR50. I've factory reset more than once.
Do I need to configure the satellite over wifi backhaul before I can wire it? Is there some magic incantation I'm missing?
Thanks.
  • Followup Q: can a satellite be added at all while the RBR50 is in AP mode?
  • CrimpOn's avatar
    CrimpOn
    Geary wrote:
    Basic config:
    This is the issue. Connecting both the WAN port and a LAN port to the same switch as the link to the modem will fail.  The Orbi only recognizes satellites when they appear on the LAN port.  Connect the modem directly to the Orbi WAN port, not to the switch.
