Bindlestick
Jun 08, 2020Aspirant
Changed SSID on my router, but the satellite still shows the old SSID
Hi everyone, I tried to change the SSID on my router and satellite last night, but it only half worked. The router is broadcasting the correct new SSID but the satellite is not. I've rebooted bot...
Jun 08, 2020Guru - Experienced User
- BindlestickJun 08, 2020Aspirant
No, but I did perform a factory reset directly before updating the firmware. I originally configured the router before powering on the satellite and then read that both should be on at the same time.
So I reset to defaults and started the base installation, which worked perfectly. Firmware was updated from 2.3.x.x as part of the installation process.
- FURRYe38Jun 08, 2020Guru - Experienced User
Theres more recent version of FW availalbe as well:
I would update the RBS then the RBR, then factory reset and setup from scratch. Use the setup wizard to walk thru the setup and add the RBS. It should connect and sync up.
2.5.1.16 is the firmware I already have. The units don't detect a new one when I check for updates.
