AKLGUY
Jun 10, 2018Apprentice
Changing from Router to AP modes, Second Satelitte
I am thinking about changing to AP mode so I can go to the same setup as I had when I had the Nighthawk R8000. And just let my Fibre Router do the work rather than going through 2 routers.
How do t...
Jun 11, 2018Guru - Experienced User
How do the satelittes work in AP mode? do they still have the WIFI backhaul? or do I need to set up each Satelitte as an AP? Does ethernet backhaul work better in AP mode?
If I stay in Router Mode and I get a second Satelitte (say RBW30 or RBS40) if this is in the middle between my RBR50 and RBS50 will I still get full strength to the RBS50? or will it be best to have the extra satelittle on the end?
The satellite behavior doesn't change when in AP or Router mode. Only the behavior of the router changes when in AP mode. Items like DHCP services, access control, traffic monitoring and such are disabled in AP mode.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
- AKLGUYJun 11, 2018Apprentice
Thanks FURRYe38
I might look at going for option 2/3
If my phone line was not a VOIP line that is router specific (or if I drop my phone line) I might just use the RBR50 as the router directly to my Fibre ONT.
Thanks again
Aaron
