MyopicWombat
Jul 14, 2025Aspirant
ChargePoint and Orbi
I’m having issues getting a ChargePoint home flex connected to my Orbi network. Their support claimed that I need to have a separate 2.4GHz network to connect to instead of a mixed 2.4GHz/5GHz mixed...
CrimpOn
Jul 18, 2025Guru - Experienced User
If that method fails, there are other methods that are more complicated (and were often recommended to owners of the newer AX systems before Netgear introduced the "IoT" WiFi network for the AX products.)
- ChrissnynyJul 30, 2025Aspirant
CrimpOn, can you post the other methods? I tried what you listed with my new ChargePoint Flex Charger, and it still can't log in to my Wi-Fi network. I have the RBR40 with three satellites. All are working very well with the other connections in the house, including IoT switches. The SSD name is there, but when I select it from the ChargePoint app, it just times out with no connection. The closest Orbi device to the charger is a RBW30. Thank you, C
