marcosoul
Jan 10, 2018Guide
Choosing the best channels
Anyone have any recommendations on how I can pick the best 2.4Ghz and 5Ghz channels? Is there free software that I can use in either Windows or Mac?
Rattler
Jan 10, 2018Guide
For the Mac, I use NetSpot and it works great. It will show all the nerby access points, channels, strength, etc. The free version is fine. It's also cool to "Map" your wifi with the paid version.
guzzijason
Jan 11, 2018Apprentice
Also, on a Mac, there are some pretty decent tools built-in!
Hold down the "option" key, and then click on the WiFi menu item. You'll see addtional items under the menu. Click "Open Wireless Diagnostics..." Then, with Wireless Diagnostics open, click on the "Window" menu to find various other tools. I have found the "Scan" tool to be particularly useful.
