The_Principal
Apr 13, 2020Follower
Chromcast connectivity issues
Can someone please help or recommend something as an alternative??? Just installed my Orbi. I use my chrome cast for my TV...it’s not connecting...can this be fixed????
1 Reply
Is this a new first installation of Chromecast or have you had this device for a while?
Are you using the same SSID name and PW on Orbi from your prior router configuration?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
