PearlandR
May 11, 2018Aspirant
Client Isolated Between Router and Satellites
Hello. Can someone help me figure out what setting i need to change so that clients can communicate between orbi devices (satellite to satellite, satellite to router, and router to satellite)? I ha...
computersteve
May 11, 2018Apprentice
Yes ive been noticing the same behavior.. devices sometimes dissapear then reappear. Meanwhile these are hardwired devices connect to the satelite... sometimes if I have devices only connected to the router, and am connected to a satelite I cant see the things connected to the router =( idk its weird lol. I think its another bug.
- PearlandRMay 12, 2018Aspirant
I hope it is just a bug. I just tried turning off fast roaming. Maybe that will help.
I saw another thread with the same subject, but it seems like their resolution was to change it to an access point instead of a router.
Has there been any discussion of a feature that could be used to force a client to disconnect?
- PearlandRAug 06, 2018Aspirant
I still haven't seen any update on this... Anyone else?
