karloy007
Dec 23, 2017Aspirant
Client Isolation between Router and Satellites?
I upgraded to an Orbi Router (RBR50) and two Orbi Satellites (RBS50) to get coverage for my house, and the backchannel speed is as great as advertised. That said, I am running into odd network issues now:
- Gamestream doesn't work between nvidia shield TV (ethernet to satellite 2) and the gaming PC (ethernet to router) anymore, the PC is undiscoverable. There were no issues using a netgear wifi extender in the before.
- My network speaker system with two Jongo A2s can't sync anymore (one connected to router wifi, the other to sat 1 wifi)
It feels like there is some sort limitation between the base router and the satellite clients, maybe some hidden client isolation setting? Maybe I need to setup static routes? Thoughts?
- DarrenMSr. NETGEAR Moderator
Yea I would try setting up static routes and see if that works.
DarrenM
- karloy007Aspirant
I addressed the issue by setting it to AP, and use the FIOS Quantum Gateway routing functionality. Another issue I discovered was that UPnP didn't work correctly. Before, I found some instructions how to set the FIOS Quantum Gateway into bridge mode and use Orbi as router, but apparently it didn't work properly. Setting Orbi to AP addressed it.
- Greystorm64Apprentice
But, why would you do that? I had the Quantum router, but I wanted to get rid of the router, so I replaced it with the Orbi for performance improvement.
Putting the Orbi into AP mode and connected to the internet through the router I wanted to replace would be defeating the purpose of having the Orbi Mesh-Network in the first place.
Wouldn't it? I might be missing something as to why anyone would do that.
I would appreciate understanding your reasoning. Might help me understand things better.
