NamHong
Feb 25, 2019Aspirant
Combine an ORBI Router + Satellite (RBR50 - RBS50) with ORBI RBR20
I have ORBI Router + Satellite (RBR50 - RBS50) which currently in use and I will have an Orbi RBR20 as a gift. Can I connect Orbi RBR20 to my current system (RBR50 + RBS50) to work as a satellite ?
ekhalil
Feb 25, 2019Master
The RBR20 can NOT be used as a satellite in your current RBK50 configuration.
If you want to use it in your current network, then the best you can get is to add it as a wired AP connected with Ethernet to the router or satellite and using different radio bands than the current network. This way you are not expanding your mesh network, but only adding an "external" AP to improve radio in some areas.
If you use the same SSID in the new AP as the one currently used in your network then expect some devices to not be able to correctly handle handover between the networks. Only devices that support latest roaming standards will be able to correctly roam between the two networks.
I would sell it and buy a satellite to improve your mesh network instead.
- NamHongFeb 25, 2019Aspirant
Thanks so much for your advice.
Where can I find any docs on which series of satellites can work with RBR50 Router beside RBS50 ?
- ekhalilFeb 25, 2019Master
The following Satellite models can work well with an RBR50 Router:
1. AC3000 RBS50
2. AC3000 RBS50Y (Outdoor Satellite)
3. AC22000 RBS20 or RBS40
4. AC2200 RBS40V (RBS40 with integrated Amazon Echo)
Please read more here: https://kb.netgear.com/000038220/What-are-the-hardware-specifications-of-the-available-Orbi-WiFi-Systems
