wifiorbim
Apr 28, 2017Follower
Combining ORBI Wifi name with current wifi name
Hi there,
I am installing my Orbi and I want to combine the name of my current wifi (ATT507) with my ORBI, so that way on my wifi options on my phone, for example, it only says one option instead of ORBI and ATT507. Thanks for the help!
1 Reply
wifiorbim wrote:Hi there,
this will effect the way the orbi works
suggest you disable the wifi transmission on the ATT507 and just use the orbi and sat for wifi functionality
