Becky2020
Aug 15, 2020Follower
Compatible Modem for Orbi Router RBR20
I have been told that the issues I am having are due to the fact that I do not have a compatible modem to my Orbi Router RBR20. Does anyone have a list of compatible modems? I cannot find one anywhere.
Thank you!
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Most DSL or cable modems are compatible with Orbi.
Some modems have built in routers, if so, This would be a double NAT (two router) condition which isn't recommended. Single function modem is recommended for use with Orbi systems.
https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NAThttps://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode - MstrbigMaster
Becky2020 wrote:I have been told that the issues I am having are due to the fact that I do not have a compatible modem to my Orbi Router RBR20. Does anyone have a list of compatible modems? I cannot find one anywhere.
Thank you!
Yiu were told wrong. The Orbi RBR20 is no different than other router.
What model do you have? And what Internet Service Provider do you have?
