RayanSF
Jul 12, 2017Tutor
Complicated Network Setup
This question assumes that Ethernet backhaul is supported. So currently my setup is like this: ISP modem (also used as the main router) ISP router connected to AP1 via Ethernet 1 ISP router conn...
- Jul 14, 2017
RayanSF Those are good reasons to change from your current setup. However, Orbi is not the solution for you if you already have wires in place and your priorities are seamless roaming, control, and monitoring. Orbi either falls short or does not include these features at all.
Yes, Orbi supports seamless roaming, but Orbi provides ZERO control over the radio channels used, or the power output, and that is a problem. Orbi provides nothing special as a router, and is very limited there also. Orbi's benefit is the wireless backhaul, which allows coverage where wires cannot easily be run. Orbi does that well, but there's nothing much past that, at least in the current firmware.
For what you want you should look at the Unifi series of wired access points and the Cloud Key controller. These provide complete control, comprehensive reporting, an excellent app for setup, testing, and monitoring, etc. There is no router included, so you'd need to use your existing router or add a new one with the features you want.
I have both Orbi and Unifi systems, so I know the capabilities of each.
RayanSF
Jul 14, 2017Tutor
st_shaw Because my existing setup doesn't support automatic roaming for devices out of the box (which I assume Orbi does) and the APs are kind of old that's why I started considering Orbi. Only considering though. In addition to automatic roaming (which I hope it supports that) Orbi has other nice features of controlling internet usage and seeing stats about it as well as other small things that actually make for a easier setup and maintanence such as automatic firmware update. Current AP have none of these features and mostly because they are just configured as APs and my ISP router doesn't give me anything to control. That's why I'm wondering what functionality will I lose if I make Orbi into only APs, will I lose these awesome functionalities?
st_shaw
Jul 14, 2017Master
