MontanaProf
Jul 17, 2018Aspirant
Configuring the Orbi RBR20 via a webpage?
Hi all,
I have a new Orbi RBR20 with one Orbi Satellite.
Since I have an old modem/router from Centurylink I would like to be able to configure that to be transparent bridging mode so that it jus...
- Jul 17, 2018
#1 would be best if you or the ISP can get it bridged.
#3 you can navigate to the routers web page and go to Advanced Tab/Advanced Settings and look for Router/AP Mode on the left side, select this and you'll see two options.
Jul 17, 2018Guru - Experienced User
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You may need to contact your ISP for help with the modem...
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
- MontanaProfJul 17, 2018Aspirant
Thanks FURRYe38.
Which of these 3 options is BEST? And when I say best, I mean gives me the most speed.
I currently have option 3 setup (Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.) although I don't know how to "configure AP mode on the Orbi router".
Thanks!
- FURRYe38Jul 17, 2018Guru - Experienced User
