MontanaProf's avatar
MontanaProf
Configuring the Orbi RBR20 via a webpage?
Hi all, I have a new Orbi RBR20 with one Orbi Satellite. Since I have an old modem/router from Centurylink I would like to be able to configure that to be transparent bridging mode so that it jus...
  • FURRYe38's avatar
    #1 would be best if you or the ISP can get it bridged.
    #3 you can navigate to the routers web page and go to Advanced Tab/Advanced Settings and look for Router/AP Mode on the left side, select this and you'll see two options.
