6old3nra1n
Nov 02, 2020Tutor
Conflicting IP shown for devices connected to Orbi satellite
I recently made the switch to ATT "gigabit" fiber and the WiFi speeds are not only worse than my previous half megabit Xfinity connection, they are also more erratic despite using the same Orbi RBR50 system. I have the Orbi set up as the router (as opposed to AP) and the Arris gateway set to IP Passthrough.
Besides the slowness, I have encountered another issue. When I use the Orbi app, it tells me that devices connected to the sole Orbi satellite have IPs in the 192.168.1.x range, while all my devices connected to the main Orbi router have IPs in the 10.0.0.x range.
Obviously when I switched to ATT and connected my Orbi, the Orbi system told me that to avoid a conflict it was changing its IP range to 10.0.0.x range. But why is it that devices connected to the satellite are still getting IPs in the 192.168.1.x range?
What makes this even more confusing is that if I log into my Orbi router using orbilogin.com, I see that those same devices connected to the satellite have IPs in the 10.0.0.x range! How is this even possible? How can the same devices have two different IPs at the same time?
One thing that I can think of is that I factory reset my main router but did not do the same for the satellite. But why would this even be necessary when the satellite itself has already been assigned a 10.0.0.x IP? Shouldn't the system be smart enough to have the satellite effectively get IPs for it's attached devices in the same 10.0.0.x range that the DHCP server is issuing on the main router?
The satellites attached devices work "fine," but I imagine there might be some downstream issue that I'm not aware of just yet.
I'm wondering if the Orbi app is just plain old buggy. I checked just now and there are several devices (like 5) connected to my satellite but the app shows only 2. The 3 missing devices are shown by the app as being connected to the main router, which isn't correct. An app restart did not fix the issue. What gives?
It makes me suspect that your arris isn't running passthrough/bridge mode properly.
Have you tried putting the arris back in router mode (disabled its wireless) and then the orbi in AP mode?
- I haven’t gotten to this point. I followed the same instructions which has often been discussed on this forum to set things up and I was able to get online so I didn’t think much of anything not working per se. But now it seems there are some other downstream issues that are present. Nothing critical (except for speed issues) in terms of errors..
6old3nra1n wrote:Obviously when I switched to ATT and connected my Orbi, the Orbi system told me that to avoid a conflict it was changing its IP range to 10.0.0.x range. But why is it that devices connected to the satellite are still getting IPs in the 192.168.1.x range?
Start with just orbilogin.com, to factor out any possible app incorrect display info. Also, check the actual IP addresses used by your device(s) and don't just rely upon what Orbi tells you. If a Windows or Mac laptop you can find the IP address and the same for most devices like Fire TV, Tivo, etc. Each device will only be using one IP address at a time.
For speed diagnosis steps start with the steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1984305/highlight/true#M7944
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopIf your host router is using 192.168.1.1 for it's address, then Orbi will auto change it's address 192.168.1.1 to something else to avoid any conficts...
6old3nra1n wrote:I recently made the switch to ATT "gigabit" fiber and the WiFi speeds are not only worse than my previous half megabit Xfinity connection, they are also more erratic despite using the same Orbi RBR50 system. I have the Orbi set up as the router (as opposed to AP) and the Arris gateway set to IP Passthrough.
