Gentlegianted
Jan 31, 2019Aspirant
Connect 2 Orbi RBR40 routers together
There was no choice for RBR 40 but we have 2 of them. Prior to me arriving at this home it looks like they were using them to gain internet access at the far end of the home. Can someone tell me how ...
- Feb 01, 2019
Advanced Tab/Advanced Settings/Wireless Settings
Gentlegianted
Hi thanks for your response. Its asking for log in information which cannt be found anywhere. Is there a way to completely reset the whole system? Start as if no one had ever set up before?
Jan 31, 2019Guru - Experienced User
Yes, press in the reset button in back of the Orbi router. Hold it until the top of the Orbi router turns AMBER, then let go. The setup wizard should be presented. Be sure to write down important information here for safe keeping.
