Gentlegianted
Jan 31, 2019Aspirant
Connect 2 Orbi RBR40 routers together
There was no choice for RBR 40 but we have 2 of them. Prior to me arriving at this home it looks like they were using them to gain internet access at the far end of the home. Can someone tell me how ...
- Feb 01, 2019
Advanced Tab/Advanced Settings/Wireless Settings
Jan 31, 2019Guru - Experienced User
AFter you connect the Orbi router to the ISP modem, turn ON the router and satellite and connect a wired PC to the Orbi router. Using a web browser, navigate to orbilogin.com and begin to walk thru the setup wizard. This will help you get the router and satellite connected.
Also download and review the installation guide from NG support site as well for additional help and information.
What is the Mfr and model# of the ISP modem the NG router will be connected too?
Gentlegianted
The modem is XFinity XFSETUP-0D85
- FURRYe38Jan 31, 2019Guru - Experienced User
Is this model# or the wifi SSID?
Look on the sticker on the modem for Model# information. I'm not seeing this particular value listed as a model#
- GentlegiantedJan 31, 2019Aspirant
Just says XFSetup there is a Part Number or PN CGM4140COM
If that helps.
I went through the set up now trying to find optimal spot to place the Orbi extender node. After I unplug and take to next location to test do I need to press Sync or will it unpon restart look for the Master device?
I notice a white pulse color on the top then it sometimes turns blue-purple. What color is it when its connected and in idle mode? So far can’t get it to give me any boost. Thanks
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.If you set up the RBS unit in the same room initially with the router, once it's setup there, all you need to do is to power it down, take it to the remote location and power it on. No need to re-sync it.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
