Laers74's avatar
Laers74
Follower
Jan 22, 2020
Connect certain devices only to certain sattelite
Hi all,
Is there a way to keep certain device only connected to a certain sattelite?
No, whenever there is a short outage of one of the sattelites, my wireless speakers (BlueSound) connect to another sattelite and, when the previous one comes back alive, the do not connect back to the previous one, so the connection is much weaker then before.
Is there a way to register the MAC addresses tot one of the sattelites?
Best regards,
Robbert
  • plemans's avatar
    Not that I know of.
    You could reboot the other satellite.
    Or get a small ups for each satellite and hook the satellites to them. That way they're not dying or shutting down.
  • FURRYe38's avatar
    30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
    You can adjust the power output of the RBRs wifi radios as well. Under Advanced Tab/Advanced Settings/Wireless Settings
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Laers74 wrote:
    Hi all,
    Best regards,
    Robbert
