ChinoMorales
Oct 06, 2019Tutor
Connect Ring Base station(Ring Security system) wired.
Hi there,
I'm installing Ring Security system and I would like to know if it's ok to connect the Base Station 'wired' to one of my Orbi satellites, if not I take the wireless route.
Thanks a lot in advance.
Thanks a lot,
Ring security system installed and working seamlessly wired to Orbi satellite.
Yes that should work. Let us know how it goes if you try this.
ChinoMorales wrote:Hi there,
I'm installing Ring Security system and I would like to know if it's ok to connect the Base Station 'wired' to one of my Orbi satellites, if not I take the wireless route.Thanks a lot in advance.
Thanks a lot,
Good to hear. Please mark your post thread as solved so others will know.
Enjoy. :smileywink:
