mrudm's avatar
mrudm
Tutor
Jan 11, 2017
Connect Satellite via Ethernet
I'm considering buying a 2 unit Orbi (router + 1 satellite). I have an existing home ethernet network, so I would connect the satellite to the router via 1 GB ethernet, giving a faster more reliable connection to the satellite.
Would this setup work?
Does the satellite have 4 ethernet ports on the back of it, just like the router? Can the satellite also function as an ethernet switch?
  • Unfortunately, the backhaul is only via wireless. This means the Satellite will always just use wireless to talk to the Router, it can't connect via wired (a lot of people want this, hopefully Netgear adds it in a FW update!).
    The Satellite does have 4 ports on the back and can switch traffic.
    • mrudm's avatar
      mrudm
      Tutor
      It is really unfortunate that the satellite can only connect via wireless and that it cannot use my existing gigabit ethernet cabling.
      This forces me to use another solution. Hopefully Netgear is listening and makes wired satellite support a priority, considering that a lot of other users have requested this. If they add this feature in the next month. then I may consider switching back to Orbi, but this is really a show stopper for me and is forcing me to use another solution that does support this feature.
      • Hydro130's avatar
        Hydro130
        Luminary
        I hear you, but please understand that the whole main selling point of the Orbi system is to provide an effective wireless backhaul solution for folks who don't have the ability (or interest) to string ethernet all over their house.
        If you have exisitng ethernet access points around yor house, you'd be better off using a (cheaper!) wired router/AP combo instead of the Orbi.
        The notion of connecting Orbi router & sat via ethernet defeats the whole point of what the Orbi system is designed expressly to do (wireless backhaul).
        TL;DR = if you have ethernet available now around your house that you can use, the Orbi system isn't the right solution for you.
  • I would like to see this as well.  I have ethernet in my house but like the technology of the Orbi for wireless.
  • Retired_Member's avatar
    Retired_Member
    st_shaw I just never quite managed to get decent roaming set up in my home. I can cover the ground floor and the basement without any problems and I even have an Unifi Outdoor AP out in the garage for the garden. However, I still haven't found a way to cover the 1st floor. I simply don't have a good position for an AP there as I don't want a WiFi AP in the bedroom and the kids' rooms. Another issue I've been facing with the AC Pros is how to mount them. I can't mount them on the ceiling as I don't have cable channels and Ethernet wiring there (reinforced concrete floors / ceilings) and the AC Pros really only perform well when mounted on the ceiling.
    I now have a Unifi Amplifi HD system deployed which covers the entire house without too many issues (except that the main router's power cable is way too short). Great app with lots of functionality. The downside is that due to the reinforced concrete floor, the Amplifi only gets a 2.4ghz signal to the basement. Amplifi will receive Ethernet backhaul capability with the next firmware update, which is awesome. But there's no way to reduce the TX power so far. I'll try the Orbi as well on the weekend, in the hopes that its proprietary tech allows a signal to get down in the basement. I'd like to be able to reduce the TX power as 100mw is total overkill for covering individual floors
    • st_shaw's avatar
      st_shaw
      Master
      Retired_Member Sounds like a challenging setup.  My Ubiquiti setup is in a single-level home. I'm currently using my APs resting horizontally on top of furniture, and they work fine like that so far. For best coverage, you're going to want your radios on the top floor, but it sounds like you have some challenges there.
      I think you'll have good luck with Orbi.  My Orbi is in a 3,000SF home with a walk-out basement and two above-ground floors.  I initially had the Orbi router on the second floor and the satellite on the first floor.  Coverage was fine everywhere, including the basement.  I also measured 10 Mbps throughput with my MacBook outside, 500 feet away from the house.  Pretty incredible.  I just upgraded my DSL and had to move the Router to the basement.  The satellite is still on the first floor.  The satellite can synch OK through the floor and the coverage still seems good. I haven't retested the maximum outside range yet though.
      • JMU1998's avatar
        JMU1998
        Luminary
        Now even Amplifi are going to offer wired backhaul why does Netgear always have to play catchup after taking the lead? Competition always see to fly past Netgear even if Netgear starts ahead, just poor feature set and slow Firmware release plagues Netgear everytime they put out something promising, Orbi still has a lot of potential but features Must improve wired backhaul is one of them now every competitor is offering it!
    Retired_Member
    st_shaw spent the entire afternoon setting up the Unifi cloud key and the network. Well, it was truly worth it: I now have full WiFi coverage in and around the house, using 4 AC Pro APs. Took me a long time to find the optimal channel and TX power combo but now it works and I'm happy. Especially since I was able to reduce RF exposure around the kids to an absolute minimum - except for the outdoor AP in the garage, everything runs at 10dbm and below.
    • st_shaw's avatar
      st_shaw
      Master
      Retired_Member That's awesome!  Good for you. I really like my Ubiquiti WAP system.  I hope you like yours.
      I also have an EdgeRouter, but that thing can be insanely complex to get setup. I'm not sure I would recommend that to anyone but a Linux guru.
  • I have separate "house" that requires an Ethernet connection to the network.
    Can a second Orbi router be set up in AP/bridge mode and connected to the network via Ethernet? Will this work as an access point?
    • rhester72's avatar
      rhester72
      Virtuoso
      No, it will appear and behave as a separate network, even if you use the same SSID.
      Rodney
  • Ok. I guess I'll have to move on to a different product.
    Thank you very much for your help!
  • Will it still act as a separate network I use a different access point (like maybe the Netgear WAC730) over Ethernet to the separate house?
    Thanks again!
